Help me pleaseeeeeeeeeeeeeeeee
HALLOOOOO
i HAVEA PROBLEM i GOT AN ANDROID T-MOBILE G1
BUT I CAN NOT USER A BLUTOOTH THIS FRIST PROBLEM
SOCOND I CAN NOT CONTACT IT WITH COMPUTER
DOES ANYONE HAVE ANY SUGGESYIONS AS
TO HOW TO OVERCOME THIS
thanking you in advance
The g1 isnt the best for bluetooth, i couldnt even transfer a standard file from a sony Ericsson fone to the g1. Are you transfer a file or trying to connect a bluetooth ear piece?
about connecting to a computer, connect the usb to g1 n pc, on the top notification bar you will see something saying to connect to pc and to mount, click on MOUNT and should work. When finished go to the notification bar and unmount it,
