green.willow
1.) Model Number ? ______Droid X_____
2.) Firmware Version ? __2.1 update 1_________
3.) Baseband Version ? _bp_c_01.09.04p__________
4.) Kernel Version ? _____2.6.29______
5.) Build Number ? _____VZW______
Also do you have a Verizon Data plan
Country you are using your phone in ? ___USA____________ (we know that not everyone is from the US)
Hello,
I am new to Droid and I think someday I will really like mine, but I am feeling overwhelmed at the moment with how to find things I need.
I wanted to listen to online radio while at work. I found an application that was supposed to work and attempted to load it to my phone. However, to do this, I need to turn off a restriction because it was not an approved application.
So I unchecked the box, but now I can't find where to recheck it, to get my security back. BTW: I ended up NOT installing the application, because I got a message indicating the program would access my email etc.
Can someone tell me where that check box is that restricts downloading. to my phone.
Hello,
