If you made a lot of changes, uninstalling programs and such, your best bet is to just SBF it back to 2.3.3.
Go to the following link and follow the instructions. You want to get the 2.3.3 SBF file to get yourself back to stock X2. Or, you could SBF to 2.3.4 if you want. It's up to you which way you want. Either way, this will unroot your phone and put it back to factory defaults. You WILL lose any apps you've installed along with your contacts. Pictures and stuff will be fine. However, you can back them up to Google and/or Verizon before you SBF and then after you SBF, you can retrieve them from Google and/or Verizon.
