Ultrasavage
I would like some help/advice on an issue I have involving Android Studio.I'm using android studio and the java language to code however, whenever I try to create a bottom navigation activity in my project only the UI folder is present however the main activity isn't present on the left hand project menu and I was hoping you could help me with this issue, just to make you aware that the problem is not because of any errors in my code and I have tried cleaning and rebuilding my project, it also isn't in the UI folder.The clip i have attached to this email will display the issue.Thank you in advance.
Yours sincerely, UltraSavageGamer
