Help me...
Dragon1996
My x bo s7 stuck in boot after modified build.prop. I don't hv pc to flash rom and I got stock recovery only. Anyone help fix my problem.
To flash ROMs on an S7 you need Odin AFAIK, which does require a PC, so you'll need to beg, steal or borrow one I think.
See if there's any manufacturer and/or signed ROMs at needrom.com or sammomile.com that you can flash with the stock Samsung recovery. Because otherwise you'll have to buy, beg, steal or borrow a PC to use Odin, that's it... Good luck.
