C cgkang65 Lurker May 25, 2011 #1 I decided do the debranding I did 3 times but, nothing happend!! Can you give me a solution? I'm using win7 and i used generic firmware nordic r1fb001 I used both of update. But it wasn't work either
beau420 Android Expert May 25, 2011 #2 cgkang65 said: I decided do the debranding I did 3 times but, nothing happend!! Can you give me a solution? I'm using win7 and i used generic firmware nordic r1fb001 I used both of update. But it wasn't work either Click to expand... So are you saying you followed this guide? http://androidforums.com/x10-all-things-root/272949-flashtool-guide-how-n00bies.html So, you downloaded and installed SuperOneClick and you used what exact version of the Firmware? And what happens when you try and flash? What does it do? What step do you get to? What error message does it show?
