Help moving from WM phone to DroidX
Hello,
I currently have a Windows Mobile phone in which I am heavily dependent on an application call Pocket Informant from a company called WebIS. It is a feature packed program that handles my Calendar/Contact/ToDo List. I find it much better than the built in Windows Mobile solution. Currently WebIS is developing a version of Pocket Informant for the Android OS. I am hoping that it will be out in August or September. In the mean time, I have purchased a DroidX and want to transfer all of my contacts, Calendar entries and Task (ToDos) over the DroidX. Can anyone offer help on the best way to do this? I would also be willing to purchased a third party app if it would make it easy and painless. I saw a program called Android Touchdown by Nitrodesk, but I am not sure that this would do want I need.
Thanks.
Steve
If you can sync your contacts with your gmail account from the WM phone do that then you can sync over to the DX. If you can't do that enter them in manually into gmail then sync them to the DX
