HELP need HTC ADP USB drivers for XP 64 bit
nextenso
Hi, please help, reached a brick wall with HTC. I have an HTC Desire Z and can not do any sync with any app incliding HTC Sync because the installer for the software is on Windows Media 11 Installer.
I run my PC on XP 64bit, the Windows Media Installer is not XP 64bit compatible, so the ADP USB drivers / HTC Sync from HTC will not install. :mad:
Does anyone know if these drivers, or HTC Sync is available on a different installer.
Regards Jonathan
Hey Jonathan,
i had same problem as you and i recently found an app for xp 64bit that solved this problem
91 PC Suite for Andriod
it will install vision version driver for xp 64bit and also has a good phone manager too
sorry man, i cant post any link in my first post in this forum
so... just search the title and you'll find it
i hope it help :)
