Help Need MPRG.mbn and msimage.mbn
My device is Zenfone Max Pro M1
ZB602KL 4gbRam 64gbRom snapdragon636 (X00TDB)
Files for sdm660 might work(X00TD)
I need MPRG_XXXXX.mbn and XXXXX_misimage.mbn
I already tried qfil and umt and qcfire
but no success emmc partition seems messed-up by previous owner.
I had emmc softwares installed on pc but 2 files are not pressent in those roms I had.
There are tuturial how to make msimage.mbn but those firmwares that I had doesn't contain "sbl.bin" and "partition.xml"
Please help. I also finding same unit that is working. any guides how to backup full emmc that might include the files i need or even just the files needed to create it.
Thanks in advance.
