Ok, I take back the part about the bad info.
It was VERY late last night when I first THOUGHT I'd figured everything out. I was wrngh. I hadn't figured everything out.
In fact, now I'm even Worse Off.
Here's what happened.
All weekend long with these uber slow data speeds something stuck in my mind from the chat with Metro on my activate about APNs. The Metro lady wanted me to type in the fast.T-mobile.com APN. I had 3 APNs already showing on my N4, a fast.metropcs.com one, a T-Mo that was almost empty and a fast.T-Mobile.com one. Now, since the chat tech NEVER said anything about rebooting to set the APN I was switching back and forth between the Metro and T-Mo one. THEN, when I used her fast.T-Mobile.com one, I got no data. I GOT data on the Metro one. She says to use whichever one I got data on "she guessed". (??) So the Metro one was what I was on all weekend with really crappy speeds.
So late last night, about 15 min before I replied to Alfick I thought, well, let's try the fast.T-Mobile.com APN again, surely Metro could At Least point me to the actually correct APN. So I changed it and rebooted. *I didn't recheck the APN though*. *Somehow* my speeds shot WAY up, at least compared to what they had been. (Just some better than my prior CDMA speeds.) I went to bed thinking the wrong APN was the problem and that you COULD get data with BOTH the T-Mobile AND Metro APNs. (Hence my thoughts about bad info.)
That's where I was wrngh.
I DID play with it and do several speed tests last night, it sure Looked Like I had another answer.
This morning I checked the APN again and it's BACK to the fast.Metro one. Not only that, but then I discover that at least the N4 Won't Let You select a completely wrong APN without it resetting it to the correct one.
Now I'm even MORE hosed.
Everything looks fine on the phone. More than enough speeds to tether, you tube, etc;.
But my tether is screwed up. Even with the always used fine Ultimate User Agent Sniffer set to "tether" or "IE 9", I can go to Gmail and Faceplant and that's it. Everything else just sits "waiting for blah blah site".
So, I'm cluelessly totally screwed up right now. At least with the crappy speeds I was able to even YouTube on tether, now I can't even do that.
I've rebooted the computer and tried a couple more times with no change. While my pooder will at least appear to connect normally with my phone WiFi, my Ipad won't even connect to it now. Grrr.
Hell if I know.
And as of midnight last night I was happily ready to put my Spirit in the mail to it's new owner today. The Spirit that I NEVER had any issue tethering with.
Now, AGAIN, I don't know What The Hell to do.
So, please accept my apology for jumping to conclusions, albeit with I Thought good reason, about getting bad info.
Bruce in Ocala, Fl
