Hello and welcome to the forums - thanks for joining!
It could be related to the APN settings - make sure you have the correct ones for your network (your carrier should be able to provide them if you can't find them on the internet). If this isn't the problem, then you might like to check out HTC EVO 3D - Android Forums for an answer from one of the other Evo 3D users on the forums.
