Help on a Zealz GK802
wwp8
I have bought a Zealz GK802 USB TV stick
and within 15mins I am having the following problems,
Youtube streaming is terrible ie; buffers alot and you get to view about 10 secs in every 5 mins, It drops the wireless to my mac mini and if i try to reconnect it rejects password, unless i power off the Zealz
When the Zealz is running it also slows down smart phones using wireless, and then recovers if I switch off the Zealz.
When I try to stream via Tvcatchup, it will play audio and not play video.
I have tested the unit for about 15mins and it gets very warm.
any help, will be appreciated, or point to the right direction
What company did you purchase your product from?
they should have a support forum that you can visit.
I am also planning to purchase this product....
Thank you.
