HELP!!!: Panda Home
Hi There,
I have an HTC Magic, and I have a bit of a issue with my Panda home and the theme I've installed on to it. It works well and everything, but I am unable to get the phone to keep the Theme permanently, for example, when you turn the phone off and the on again, it reverts back to the normal droid system theme, I have to go and open Panda Home to get the theme up. As well as, Task Killer also kills the theme as well.
How can I get the phone to keep Panda Home running without reverting back?
Much appreciated XD
-Alexandra Rose
When the phone is on, hit the home button. You should see 3 options, Panda Home, Home and HTC Sence. Before you choose Panda, hit the check on the bottom " Use by default for this action". Then it should always go to Panda on its own. That's if I'm understanding what you mean.
Well, I tried the setting> Dynamic Theme. Thats a no go.
I tried hitting home when the phone is on, and all it does it get rid of panda home theme, and returns to the normal HTC one. But when you hold the home button down, it just comes up with quick links (to like messaging, etc).
Im not suring if I have done it right though... =S
Don't hold down the Home button, just click it. It should give you those options (make sure you select "Make default" before you select Pandahome).
If it's not giving you those options, go to Settings>Applications>Manage Applications>Home (not Pandahome), and select Clear Defaults. After you've done that, click the Home button and it should then give you your options.
There's an app called Home switcher which lets you set which homescreen you want as the default. Its good if you want to revert back to the sense one.
I have a Samsung Moment and recently got Panda Home I admit I'm slow w/it so if anyone can tell me a simple them preferrable blue in color I'd appreciate it. Thanks so much.
OK, I am not getting any of the above !!! When I click the Home button, I just get the last 6 applications I used. So, then I went to Settings>Applications>Manage Applications> (but I have no Home) under Manage Applications. I only have Pandahome. Help please:eek:
The only thing that really bugs me about the Panda-home is that it slows down my MyTouch 3G drastically. But, besides for those minor inconveniences its a great app.
