Help Please LG V20 ADB Issuses
I went throug over 20 forums sites videos none of them helped me I forcfully manually installed abd drivers reconizes when the phone is on adb devices but when I do adb reboot bootloader and do adb devices nothing pops up in device manager I changed the driver around few times till shows norhing killed adb server truned it back on nothing rebooted my pc use diffrent usb port have nothing plugged into any other port Have owm unlocking bootloader is unlocked usb debugging is on I did put media transfer for files them ptp for pictures still no change I installed lg air drive thing still get same resutls. When I do fastboot devies it shows up there in bootloader or not.
adb push dirtycow /data/local/tmp
adb push recowvery-applypatch /data/local/tmp
adb push recowvery-app_process64 /data/local/tmp
adb push recowvery-run-as /data/local/tmp
I have to push those commands but I dont know how with fastboot command since there is no adb devices I tried also on 5 different os using android tool kit latest's android usb drivers some adb installer thing where you select Y for all options I tried on parrot os kali linux windows 10 pc and two windows 7 pc I have windows 7
I tried almost everything an the driver shows up in device manager please help
BTW It wasnt like that before it was before under android device tab as a good adb device lge adb deice I tried them all and if I dont respond I may be asleep
LG V20 android 7.0 T-Mobile
Adb commands are ran while normally booted or within a custom recovery as well as some stock recoveries.
Fastboot commands are ran in bootloader mode or fastboot mode. The V20 "Dirty Santa root" was patched after i believe ZV5.
I have 7.0 Build Number NRD90M Soft Version H91810q
You did enable developer mode on your phone and turn on debugging, right? Once debugging is enabled and you plug in your phone, you have to grant permission for the phone to connect on the phone (it should pop up the first time).
Sorry if that's too obvious. Just want to cover all the bases.
Yes i believe the second latest version of my phone is unrootable but i wont give up out of 7billion people in the world and this phone update being out for quit some time no one NOT one has a way to root LG V20 H91810q depressing
