Hello all - sorry if I've posted this in the wrong place - I'm new to the forum.
I've gone and got myself into a bit of a bind.
I did an 'uninstall updates' for Google Maps (long story, not relevant), and now:
Any help would be much appreciated!
- If I select Maps from the "Applications" folder I get a message saying "Application is not installed on your phone",
- Also, if I go to Settings -> Applications -> All it's not listed there.
- BUT, if I then go to the "Play Store" it tells me that the app is "Installed", so it won't let me re-install / update it.
