Hi I'm new to this and struggling a bit with trying to sort out my sound. Here's the problem. I have installed Kryillos 7.1 modded rom and for the most part it works sweet with only a couple of freezes/crashes every so often. The problem I'm having is with the sound the speaker distorts and sounds like it has blown if I have the volume up any higher than half. I know there is nothing wrong with speaker itself as it was working fine before the install. I can only assume it is the Voodoo sound controller that came with Kryillos.
I can't see any way to revert the sound back to the original control as I think it probably isn't there anymore. Any help would be really appreciated
