Help Help Please...Tablet screen will not turn on
ashash95
Ok, so i dropped my tablet for the first time and now it is all messed up...whenever i try to turn it on it will make the start up sound but the screen remains black...please someone help me
Hi, it doesn't sound hopeful unfortunately.
Obviously the drop has caused some sort of internal damage, unless you're comfortable opening it up and taking a look yourself, there's not much you can do, sorry :(
You could try calling Asus, but I'm not sure what they'd charge you for a fix.
More than likely a cable came loose to the display. To test get a HDMI to Mini HDMI and connect to a TV, if it works the 2 things that coul be wrong are 1. loose cable, 2. Damaged display.
If you want to open it do a search for how to open an ASUS EE Pad, or ASUS transformer.
Ifyou don't want to fool with it and you are in the US there is a company in San Diego that repairs TF's.
