Help!! Please!!
mimi2012
I seemed to have destroyed my Samsung Gravity Smart Android 2.2 operating system.
It all began when I rooted my device using SuperOneClick then installed Titanium Back-up. I accidentally removed the dialer app (HOW DOES THAT HAPPEN?) and immediately lost service and all dialer related functions. In a moment of panic I did a factory reset on it, but it was very unsuccessful and now I'm stuck on the "Tap the Android to begin!" screen. When I tap the Android it doesn't do a thing, unlike my previous factory resets. Is there a way to restore the Android 2.2.1 OS manually? Without the com.android.phone, there's no way to restore it on the device.
Hello and welcome to Android Forums. I'm sorry to see that you are having problems with your phone.
You will need to check in with the experts over at the Gravity Smart - All Things Root - Android Forums they are the ones who can help you out with this problem. Hopefully, they'll have you straighten out and have you back on track.
Good luck!
