help please
  • Start date Start date
A
Android Question
Guest
So my apps on the flytouch wasn't working so my mom said we might have to reset it but I did. It by my self now nothing. Is on it I'm in huge troble please tell me how I can replace everything with out buying anything ��
Hello. Thank you for bringing your question to us. :)
Do you have the Flytouch 2, Flytouch 3 or the Flytouch 4? There is a difference between the two with regard to the factory data reset, and also in other remedies for various issues. Let us know as soon as you can, please.
Meanwhile, shut it down and pull out the battery and SIM card and the sd card. Put it all back in and try a boot up. But before we go further we need to know which one you have. :)
