Your best bet would be to visit this subforum: Marquee - All Things Root - Android Forums. You'll find information about rooting the Marquee there. Start from the sticky post "Marquee All Things Root Guide", and also look for threads where poeple are asking similar questions. If you are unfamiliar you may need to read things a few times before it starts to make sense - don't worry, that's normal! It's important to understand what you are doing before you try it.
If you have any questions, I'd suggest registering so that you can post in that section. Rooting procedures depend on the device, so it's best you ask questions to people who are familiar with that device, and that section is the best place to find those people.
