Help rooting
I need someone to root galaxy s6 edge and y kindle hd8 8gen
  • Any
    Votes: 0 0.0%
  • Any
    Votes: 0 0.0%
  • Total voters
    0
It unlockes lost of performance capability that's blocked by manufactures I tried 1 click root and I'm not wanting to waste 30$ if it don't work or if I can have it done cheeper online
Im have never used Oneclickroot. The preferred method is to install a custom recovery like TWRP and flash Chainfile SuperSu or Magisk. Its important to have an unlocked bootloader. Also follow steps to open "developer Options and enable USB setting to connect to a pc. Go to about pone and tap buildnumber 5 to 7 times. Theme go back and look for a new "developer options" settings. Be aware of FRP lock as you will need to know you Google pasword. If you forget it you'll be permanently lock out of your device .
