Hi!
I bought 2 Sanei n10.
They were so laggy so i tried to upgrade one of them to android 4.0.4 using LiveSuit. After a sucessfull upgrade the tablet shows the boot logo but then turns into a white screen.... And nothing happens.
Been googling around for days now and someone wrote to re-flash the tablet a couple of times cause it can be stubborn.
So i tried to downgrade it to 4.0.3... Same stuff. So i upgraded it and downgraded it 20 times now and still the same.
Is the tablet bricked or is there any hope?
Maybe i should try root it or is that impossible now?
Or is the russian way the only solution (sledgehammer)?
Any suggestion or thought would be appriciated!
