Root HELP, semi-BRICK
nosar77
So i was trying to boost the sound on my phone and most of the hacks showed to user Mixer_paths.xml in the system folders i tried to change it and now no sound on my phone works can someone please upload a saved one from their LG l70 please and i need it ASAP
the xml can be found in
/system/etc.. and its in that folder please help me!!!
i need my phone for everyday use! no backup :(
Here you go! Fresh out of an LG L70 :) mixer_paths
Thanks you so much luisramon17, you are amazing for that, that fixed it up very fast, and honestly i think i might have accidentally changed permissions which might have made it unusable thank you so much tho!
