Help Help setting up WIFI (Android 2.2)
fdelente
Hello.
I have a new T301 that came with Android 2.1, but couldn't connect to my home WIFI network.
I upgraded to 2.2 since some posters said that it would solve the problem, but it hasn't.
I have checked the Cruz support site, but haven't found any relevant info.
Can anybody help me on that? The tablet shows my network SSID, tried to connect to it, but fails and doesn't give any explanation why.
Thanks!
Have you tried to disable the password protection on your WIFI network? It could be the protocol that you used in your router is not compatible with your tablet.
I've also seen people setup the network 3+ times before it connects. Delete it & try again. If you get to 5 attempts, double check your security protocols of the router as previous post suggests.
