Help! System UI?
blh2012
Ok, so on older HTC Android Phones, there was an option to clear the defaults for Sense and then use the stock android launcher for your homescreen. I was checking out the apps list to see if the stock launcher was included with the one V, and I couldn't find the "Home" app but I did find one called "System UI"...Could this be the stock launcher?
EDIT: I just cleared the defaults for the HTC Sense UI and when I hit the home button, instead of asking me "Which program do you want to use to open this?" like other Androids would, this simply just took me back to the HTC Sense homescreen..Even on my HTC Evo V 4G it would ask me that question when I cleared Sense defaults even though Sense was the only UI installed.
I just really hate using launcher apps from the market...
It doesn't have an option like that on the One S either, so it probably isn't there for any of the new htc phones.
All I can suggest is a launcher like nova or apex.
