Apps Help taking screenshots via SDK.
iamkewl
Member
I'm trying to take screenshots of my droid..but when I try and run "ddms" all that happens is a cmd promt screen flashes and then disappears.
Any help?
Try opening a command prompt and pulling the DDMS into the prompt and running it you should get an error.
A very rough guess would be that your CLASSPATH path is not setup in environment config.
Tom
Anyone interested in Beta testing Android apps can join the Polarmobile beta program here Beta Enroll | Polar Mobile
