Quencyjones79
Hello good morning for everyone I´m a beginner on the Android Studio, and i need a help for you to place well the app, that means working perfectly. It´s a good app, and it could serve me as a example to understand its funcionality.
I´m building an audio music player app., but on my MainActivity.java file ,
In the code i faced with some mistakes, see below the images that i sent you. How could you fix them?
MainActivity.java
AndroidManifest.xml
AlbumFragment.java
MusicFiles.java
fragment_album.xml
SongsFragment.java
fragment_songs.xml
Ps.: I send also the ZIP file about the audio music player app, My Android version is below:
Another trouble is the emulator that in my pc doesn´t work, i think it´s because my Pc doesn´t have the Intel processor but the AMD Processor. Could you help to fix this problem too? see the images
Could anyone, help me, please to fix this problems?
I expect your answer as soon as possible.
Best regards
José Moreira
MainActivity.java
Java:
package com.example.musicaudioplayer;
import androidx.annotation.NonNull;
import androidx.annotation.Nullable;
import androidx.appcompat.app.AppCompatActivity;
import androidx.core.app.ActivityCompat;
import androidx.core.content.ContextCompat;
import androidx.fragment.app.Fragment;
import androidx.fragment.app.FragmentManager;
import androidx.fragment.app.FragmentPagerAdapter;
import androidx.viewpager.widget.ViewPager;
import android.content.Context;
import android.content.pm.PackageManager;
import android.net.Uri;
import android.os.Bundle;
import android.provider.MediaStore;
import android.widget.Toast;
import com.google.android.material.tabs.TabLayout;
import java.util.ArrayList;
import java.util.jar.Manifest;
public class MainActivity extends AppCompatActivity {
public static final int REQUEST_CODE=1;
ArrayList<MusicFiles>musicFiles;
[USER=1021285]@override[/USER]
setContentView(R.layout.activity_main);
permission();
initViewpager();
private void permission() {
if(ContextCompat.checkSelfPermission(getApplicationContext(), Manifest.permission.WRITE_EXTERNAL_STORAGE)
!= PackageManager.PERMISSION_GRANTED) {
ActivityCompat.requestPermissions(MainActivity.this, new String[]{
Manifest.permission.WRITE_EXTERNAL_STORAGE}
, REQUEST_CODE);
else
Toast.makeText(this, "Permission Granted!", Toast.LENGTH_SHORT).show();
musicFiles = getAllAudio(this);
public void onRequestPermissionsResult (int requestCode,@NonNull String[]permissions,
@NonNull int[] grantResults){
super.onRequestPermissionsResult(requestCode,permissions,grantResults);
if (requestCode==REQUEST_CODE)
if(grantResults[0] == PackageManager.PERMISSION_GRANTED){
//Do whatever you want permission related
Toast.makeText(this, "Permission Granted !", Toast.LENGTH_SHORT).show();
musicFiles =getAllAudio(this);
else
ActivityCompat.requestPermissions(MainActivity.this, new String []{Manifest.permission.WRITE_EXTERNAL_STORAGE,
REQUEST_CODE);
private void initViewpager(){
ViewPager viewPager =findViewById(R.id.viewpager);
TabLayout tabLayout = findViewById(R.id.tab_layout);
ViewpagerAdapter viewPagerAdapter = new ViewpagerAdapter(getSupportFragmentManager());
viewPagerAdapter.addFragments(new SongsFragment(), "Songs");
viewPagerAdapter.addFragments(new AlbumFragment(),"Album");
viewPager.setAdapter(viewPagerAdapter);
tabLayout.setupWithViewPager(viewPager);
public static class ViewpagerAdapter extends FragmentPagerAdapter{
private ArrayList<Fragment> fragments;
private ArrayList<String> titles;
public ViewpagerAdapter (@NonNull FragmentManager fm){
super(fm);
this.fragments = new ArrayList<>();
this.titles = new ArrayList<>();
void addFragments (Fragment fragment, String title){
fragments.add(fragment);
titles.add(title);
@NonNull
public Fragment getItem (int position){
return fragments.get(position);
public int getCount(){
return fragments.size();
[USER=1996173]@nullable[/USER]
public CharSequence getPageTitle(int position){
return titles.get(position);
public static ArrayList <cMusicFiles> getAllAudio(Context context){
ArrayList<MusicFiles> tempAudioList = new ArrayList<>();
Uri uri= MediaStore.Audio.EXTERNAL_CONTENT_URI;
String[] projection = (
MediaStore.Audio.Media.ALBUM,
MediaStore.Audio.Media.TITLE,
MediaStore.Audio.Media.DURATION,
MediaStore.Audio.Media.DATA, // FOR PATH
MediaStore.Audio.Media.ARTIST,
Cursor cursor = context.getContentResolver().query(uri, projection, null,null,null);
if (cursor!=null)
while(cursor.moveToNext())
String album = cursor.getString(0);
String title = cursor.getString(1);
String duration = cursor.getString(2);
String path = cursor.getString(3);
String artist = cursor.getString(4);
MusicFiles musicFiles = new MusicFiles(path, title,artist,album,duration);
//take log.e for check
Log.e("Path: " + path, "Album : " + album);
tempAudioList.add(musicFiles)
cursor.close();
return tempAudioList;
AndroidManifest.xml
Code:
<?xml version="1.0" encoding="utf-8"?>
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
package="com.example.musicaudioplayer">
<uses-permission android:name="android.permission.WRITE_EXTERNAL_STORAGE"/>
<application
android:allowBackup="true"
android:icon="[USER=22138]@Mipmap[/USER]/ic_launcher"
android:label="[USER=696546]@String[/USER]/app_name"
android:roundIcon="[USER=22138]@Mipmap[/USER]/ic_launcher_round"
android:supportsRtl="true"
android:theme="[USER=19691]@Style[/USER]/AppTheme">
<activity android:name=".MainActivity">
<intent-filter>
<action android:name="android.intent.action.MAIN" />
<category android:name="android.intent.category.LAUNCHER" />
</intent-filter>
</activity>
</application>
</manifest>
AlbumFragment.java
Java:
import android.view.LayoutInflater;
import android.view.View;
import android.view.ViewGroup;
* A simple {@link Fragment} subclass.
public class AlbumFragment extends Fragment {
public AlbumFragment() {
// Required empty public constructor
public View onCreateView(LayoutInflater inflater, ViewGroup container,
// Inflate the layout for this fragment
View view = inflater.inflate(R.layout.fragment_album, container, false);
return view;
MusicFiles.java
Java:
public class MusicFiles {
private String path;
private String title;
private String artist;
private String album;
private String duration;
public MusicFiles(String path, String title, String artist, String album, String duration) {
this.path = path;
this.title = title;
this.artist = artist;
this.album = album;
this.duration = duration;
public MusicFiles() {
public String getPath() {
return path;
public void setPath(String path) {
this.path = path;
public String getTitle() {
return title;
public void setTitle(String title) {
this.title = title;
public String getArtist() {
return artist;
public void setArtist(String artist) {
public String getAlbum() {
return album;
public void setAlbum(String album) {
this.album = album;
public String getDuration() {
return duration;
public void setDuration(String duration) {
fragment_album.xml
Code:
<FrameLayout xmlns:android="http://schemas.android.com/apk/res/android"
xmlns:tools="http://schemas.android.com/tools"
android:layout_height="match_parent"
tools:context=".AlbumFragment">
<!-- TODO: Update blank fragment layout -->
<TextView
android:text="[USER=696546]@String[/USER]/hello_blank_fragment" />
</FrameLayout>
SongsFragment.java
Java:
public class SongsFragment extends Fragment {
public SongsFragment() {
View view =inflater.inflate(R.layout.fragment_songs, container, false);
return view;
fragment_songs.xml
Code:
tools:context=".SongsFragment">
<TextView
</FrameLayout>
Best regards
José Moreira
I also added code tags for readability. Good luck!!
