Help UCCW
Hey guys how do you:
1.) Get a working Missed call count (mine doesn't update automatically)
and also how do you which launch the dialler/call history on touch of the missed call count?
2.) Get a working Unread text msg count, which opens the messaging app on touch?
Thanks
Thanks
Uccw has an option for misscalls and unread message count you can put those in your widget
Thanks
1. Add "missed calls" from the menu options, set the size/font/color/ placement
2. Go to hotspots, hit "hotspot", then "uccw" then dialer (or hotpot>App>Phone)
Then move the hotspot so it is over your "missed calls" number
Save skin
Then hit the top right dots, Lock widgets (Hotspot mode), On
