Help Help: ViewSonic ViewPhone3 V350T original software
Hi,
I am Srinivas from India.
First of All thanks to everyone here for your valuable support.
I recently bought a ViewPhone3 (V350T) dual sim phone in India.
I am new to use android version and this is my first android mobile.
But unfortunately viewsonic is not giving help and
support for this mobile phone.
The lucky thing is I found this forum after searching one week to try root my phone.
Now I am coming to point.
To root my phone I flashed my mobile V350T with "firmware_root_MarcoCH.7z" using "SUT LR".
"www.rapidshare.com/files/253791827/firmware_root_MarcoCH.7z".
all went fine and the mobile is rooted now.
But the problem is there is no separate ring tone for my dual sim phone.
before root I have two separate ringtones.
I did unroot my phone with "SuperSU" google market application and tried to update via mobile network.
still no luck it is saying "your sotware is upto date. No newer versions available".
I did try many "Factory Default Settings" but no use.
Could you please help me to get back my original firmware?
thanks and regards,
Srinivas.
some usefull information to diagnose the problem
Before I install this software :
(OS:android 2.3.7,
baseband version:MP,
Kernel Version: Apps_2.6.35-perf,
Build Number: 5057_4_39C,
android system recovery 3e.
bootloader: v.446C Built at feb 1 2012 19:28:37
FlashMem: KFM4G16Q2A
orig hwid :0x010d1007
incoming dowload mode
SWVer=4.39C
Model=FAD
HWVer:0x010d1007
RF band id=GSM_BAND_1234,WCDMA_BAND_128
FTM_ver=3.590
SW_Model=5057
flex=013
Build_Numer=A03)
After Insatallation :
(OS:android 2.3.7,
Kernel Version: Apps_2.6.35.11-perf,
Build Number: 4100_4_350,
Bootloader: v.439A built at nov 29 2011 18:03:47.
Flash Mem: KFM4G16Q2A.
It is downgraded.
is there any way to upgrade my bootloader ? )
