Ramkumar S
My device is Samsung Note 5.
Every time I put the volume on '0' level... But, moments later I check it the Volume is turned to fully on...
I don't know which app is changing the volume (I have disabled 'Change System Settings' for the apps listed there)...
How to know which app is changing and why is there a permission or other means to restrict it...
When I open Whatsapp/FB etc.. If the vids play at high volume and that is really annoying...
I even installed 'App Volume Control'... But, the thing is it doesn't provide a 'Turn off volume for all' or something...
I really want to identify the App and uninstall it... No app should have rights to change my vol settings...
I am disappointed that 'Android' did not provide an option to limit apps from changing vol without permission...
Can someone please help...
Thanks.
Thanks.
