Root Help with a brick
trav473
Hi RAZR folks, Wonder if I could get some help from some of you. I got me a bricked RAZR (XT912) with no story behind it... Best story that I got was "I was installing apps, and now it won't boot!!" So I have no idea if the thing was rooted or not, and assume that it was on ICS. I have tried just about every trick I can find on all these forums, but I keep getting stuck at the same place. The farthest I have gotten this thing back to functional is using the RAZRUtility from MattGroff, version 1.82. I am trying to restore this thing back to total stock so that I can start fresh with it. Everything flashes okay, except the 'boot.img' file. Even using RDS, every fastboot file I try hangs at flashing the boot.img. Any suggestion would be great. TIA
Of course it would be easier if you knew what actually happened!
Perhaps it bricked while doing JB upgrade? Try using unbrickxt912JB zip but make sure you have the JB leak on your SD card first.
Found the unbrick utility and the JB OTA. Took me a few trys because I kept getting a status 7 failure on the OTA install, but it finally took, and RAZR is up and running. Thanks very much.
