I'm currently working on building some apps for the Andriod Market and I'm having trouble with installing ADT for Eclispe when i try to install it it fails. I need help if anyone could help me out i would be very grateful !!
Start Eclipse, then select Help > Install New Software.
Click Add, in the top-right corner.
In the Add Repository dialog that appears, enter "ADT Plugin" for the Name and the following URL for the Location:
https://dl-ssl.google.com/android/eclipse/
Click OK.
n the Available Software dialog, select the checkbox next to Developer Tools and click Next.
In the next window, you'll see a list of the tools to be downloaded. Click Next.
Read and accept the license agreements, then click Finish.
when it attempts to install it says this:
Cannot complete the install because one or more required items could not be found.
Software being installed: Android Development Tools 20.0.3.v201208082019-427395 (com.android.ide.eclipse.adt.feature.group 20.0.3.v201208082019-427395)
Missing requirement: Android Development Tools 20.0.3.v201208082019-427395 (com.android.ide.eclipse.adt.feature.group 20.0.3.v201208082019-427395) requires 'org.eclipse.wst.sse.core 0.0.0' but it could not be found
idk what to do someone hlep me plz
Click OK.
