Help Help with browser
New to this forum so not sure what topic it belongs in but I obviously installed some dogey app and now I keep getting spam notifications and when I go on the site setting to disable it its blacked out and wont let me disable it
Welcome to Android Forums, Laming19961!
Just to be clear, you installed it, but now in your System Settings, its only option is 'disable' [not 'uninstall'], but it's grayed out so you can't disable it? Uh-oh! :o
Please post a screenshot of the app in System Settings. Also, the name of the app and its Play Store link would be helpful. I'm assuming you installed it from Play; if that's incorrect, please tell us where you got it--again, a link to it would be helpful.
You might try starting the device in safe mode and see if you can uninstall it then.
Worst case scenario, you might need to do a factory reset.
