I have an android GTV 220 smart tv box.To install wi fi it tells me to go to ethernet then connection type check either DHCP
static IP
THEN MAC ADDRESS [redacted] then check
IP ADDRESS
NETMASK ? IS THAT THE PIN NUMBER OF MY MODEM?
DND ADDRESS?
DEFAULT GatewaY
i HAVE MY IP ADDRESS BUT NOT SURE WHERE TO GET THE OTHER NUMBERS FROM
i HAVE NOT INSTALLED SD CARD AND WANT TO RUN IT OFF MY HOME DEVICE NOT MY MOBILE DEVICE
aLL HELP GREATLY APPRECIATED
I HAVE BEEN ON THIS CASE FOR 2 DAYS...GRRRR
static IP
IP ADDRESS
DND ADDRESS?
DEFAULT GatewaY
