Hi developers,
I'm trying to create an application that reads the contacts and print them. I did read the contacts but the problem is in printing them. I don't know how to print them as a list so when I run my code it just gives me only one contact. My code is shown below:
The main activity file:
package com.cons;
import android.app.Activity;
import android.database.Cursor;
import android.os.Bundle;
import android.provider.Contacts.People;
import android.widget.TextView;
public class Contacts extends Activity {
private String r;
private TextView t;
@Override
public void onCreate(Bundle savedInstanceState) {
setContentView(R.layout.main);
t = (TextView)findViewById(R.id.TextView1);
// Get a cursor over every contact.
Cursor cursor = getContentResolver().query(People.CONTENT_URI,
null, null, null, null);
// Let the activity manage the cursor lifecycle.
startManagingCursor(cursor);
// Use the convenience properties to get the index of the columns
int nameIdx = cursor.getColumnIndexOrThrow(People.NAME);
int phoneIdx = cursor. getColumnIndexOrThrow(People.NUMBER);
String[] result = new String[cursor.getCount()];
if (cursor.moveToFirst())
do {
// Extract the name.
String name = cursor.getString(nameIdx);
// Extract the phone number.
String phone = cursor.getString(phoneIdx);
result[cursor.getPosition()] = name + " (" + phone + ")";
r = result[cursor.getPosition()];
t.setText(r);
} while(cursor.moveToNext());
My main.xml file:
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
android
rientation="vertical"
android:layout_width="fill_parent"
android:layout_height="fill_parent"
<TextView
android:id="@+id/TextView1"
android:layout_width="wrap_content"
android:layout_height="wrap_content">
</TextView>
</LinearLayout>
The manifest.xml:
<manifest xmlns:android="http://schemas.android.com/apk/res/android"
package="com.cons"
android:versionCode="1"
android:versionName="1.0.0">
<application android:icon="@drawable/icon" android:label="@string/app_name" android:debuggable="true">
<activity android:name=".Contacts"
android:label="@string/app_name">
<intent-filter>
<action android:name="android.intent.action.MAIN" />
<category android:name="android.intent.category.LAUNCHER" />
</intent-filter>
</activity>
</application>
<uses-permission android:name="android.permission.READ_CONTACTS"></uses-permission>
</manifest>
I know there is should be a way that can be done in main.xml file to print the contacts in a list way and my question is how??
With my bwst regards.
package com.cons;
private String r;
private TextView t;
@Override
do {
t.setText(r);
My main.xml file:
android
<TextView
</TextView>
</LinearLayout>
The manifest.xml:
package="com.cons"
<intent-filter>
</intent-filter>
</activity>
</application>
</manifest>
