I've been asked to fix a laptop, and I just need advice on what to do.
Main problem is that backing up doesn't work (not sure if it even used to) using windows backups because of something to do with shadow hard drive something-or-other.
I think the best thing is to wipe and reinstall windows but am I right in thinking it'll all work fine once I install the drivers (from the manufacturer website)?
Because it's not my laptop, I don't want it to be any worse after messing about with it. Obviously I'll try making a system restore disk before the wipe, but I'm scared some things might not work as well (with a custom desktop it's much easier)
