Help with Galaxy S5 Marshmallow 6.0.1
coolguy2218
I just upgraded my phone from lollipop to marshmallow and now I can't open the phone , contacts or messaging app, and if it does finally load, the names of the contacts don't show up. Can you please give me a fix without factory resetting it, as this phone is used for my dads work. Thanks!
Don't understand why there should have been an issue there to start with.
Try this:
Power phone off:
3 finger restart;
  • Volume Up
  • Home Key down
  • Power Button held ON
When Blue menu shows up, release buttons, wait for it to stabilize.
Use Volume button to select Clear Cache Partition.
then Restart the phone
Try this:
Power phone off:
3 finger restart;
  • Volume Up
  • Home Key down
thanks!
A Factory Data Reset is devastating. The logic is ... after you do a major upgrade at sometime you will be forced into a Factory Data Reset. Plan on it and do it when it is least inconvenient.
I use Nova Launcher Prime, Pixel Phone Pro, and Tasker. They each have backup/restore capabilities so restoring my settings across a Factory Data Reset is not a big deal.
You can do the Wipe Cache Partiton at any time and it might resolve your current issues while you decide on the Factory Data Reset. (I do a Wipe Cache Partition on my Droid Turbo 2 every Saturday as part of weekly maintenance.)
... Thom
