Help with mobile atlas creator for maverick please
jaybo1973
Android Expert
Hi guys
Has anyone got any experience with mobile map creator and maverick?
I can create a map, and if i put the files in one of the existing folders in the maverick folder on the SD card, it is fine. It is OS map info I am after, so I need a new folder so not to write over other map info such as google maps, bing etc. If I put a new folder called OS maps in the maverick directory, maverick can't see it, i.e, it still only has the standard map tabs in the app:
Map link, Osma
Google maps, satellite, Terrain
Bing maps, satellite Hybrid
Wikimapia
Any advice would be great
Thanks
