Help Help with movies
I copied 4 movies to my movies folder (when you plug in your phone, double click on it and the root folders pop up, I dragged my movies into the empty movies folder)
So I have 4 movies in the movies folder, but the names of the movies do not show up, just 4 thumbnails of the movies.
Any way to see the labels?
If you're wanting to watch movies, I wouldn't expect the gallery app is the ideal app. This is mainly for videos you take, where seeing what it is should be self explanatory.
I cannot recommend a better player myself as I dont really do this, but Either browsing with a file explorer and opening with a proper video player or using the player itself would make more sense to me.
