Help help with mytouch 4g/ clockwork
I factory reset my mytouch 4g through the settings menu....now it won't work. It turns on and freezes on the welcome screen. I factory reset it with clockwork on it. the sd card was formatted on my blackberry, then formatted through clockwork on my android and now i have all the mytouch 4g files back on the sd card. If there is a thread with an answer to this...i have not found it. it is my first android phone. I tried turning it on without the sd card and it still freezes. The only way i can access my sd card is through clockworkmod recovery v3.0.2.4, but i have to mount usb storage in order to. i put PDIMG15.zip on my sd, but everytime i try to install it through cw, it won't install. I did not root this phone. I bought it like this and had no idea when i factory reset it that it had cw installed.
