androidmahfuz
Hi,
Basically I am following this tutorial - http://www.myandroidsolutions.com/2013/08/04/android-listview-with-searchview/.
The search functionality works fine, however, when I click on a search result it crashes. I cannot work out what the arraylist namelist does in the MyActivity class, and I believe this is what is causing the app to crash.
My version, unlike the tutorial, has more than just one 'name' column. I have also parsed xml into the database. I have highlighted some of the lines to do with what I think is causing the app to crash.
My version of the main class, in which I have commented question marks over, where I don't understand how to adapt.
public class SearchActivity extends Activity implements SearchView.OnQueryTextListener,
SearchView.OnCloseListener {
private SearchView searchView;
private ListView myList;
private BooksDBAdapter mDbHelper;
@SuppressWarnings("rawtypes")
private ArrayList<String> nameList;
private MyAdapter defaultAdapter;
private static String myTag = "Books";
@override
setContentView(R.layout.search);
//ArrayList nameList = new ArrayList<String>();
//relate listView from java to the created xml
myList = (ListView) findViewById(R.id.listView);
//show list
// defaultAdapter = new MyAdapter(SearchActivity.this, nameList);
//myList.setAdapter(defaultAdapter);
//for simplicity we will add the same name for 20 times to populate the nameList view
// for (int i = 0; i< 200; i++) {
// nameList.add( + i);
//set searchview
searchView = (SearchView) findViewById(R.id.searchView);
searchView.setIconifiedByDefault(false);
searchView.setOnQueryTextListener(this);
searchView.setOnCloseListener(this);
mDbHelper = new BooksDBAdapter(this);
mDbHelper.open();
//Clear all names
mDbHelper.deleteAllBooks();
//Create the list of names which will be displayed on search
//for (String name : nameList) {
// what
XmlResourceParser xpp = getResources().getXml(R.xml.books);
try {
mDbHelper.open();
// get initial eventType
while (xpp.next() != XmlPullParser.END_TAG) {
if (xpp.getEventType() != XmlPullParser.START_TAG) {
continue;
String name = xpp.getName();
if (name.equals("book")) {
String author = null, title = null, genre = null, price = null, publish_date = null, description = null;
continue;
switch (name) {
case "author":
author = readText(xpp);
break;
case "title":
title = readText(xpp);
break;
case "genre":
genre = readText(xpp);
break;
case "price":
price = readText(xpp);
break;
case "publish_date":
publish_date = readText(xpp);
break;
case "description":
description = readText(xpp);
break;
mDbHelper.createBooks(author,title,genre, price, publish_date, description);
} catch (XmlPullParserException | IOException e) {
e.printStackTrace();
}finally{
Log.d(myTag, "Database created");
private String readText(XmlPullParser parser) throws IOException,
XmlPullParserException {
String result = "";
if (parser.next() == XmlPullParser.TEXT) {
result = parser.getText();
parser.nextTag();
return result;
@override
protected void onDestroy() {
super.onDestroy();
if (mDbHelper != null && mDbHelper == mDbHelper.open()){
mDbHelper.close();
@override
public boolean onClose() {
displayResults("");
return false;
@override
public boolean onQueryTextChange(String newText) {
// if (!newText.isEmpty()){
displayResults(newText + "*");
// } else {
// myList.setAdapter(defaultAdapter);
return false;
@override
public boolean onQueryTextSubmit (String query) {
displayResults(query + "*");
return false;
//search and results method
private void displayResults(String query) {
//REMEMBER I ADDED .toString()
Cursor cursor = mDbHelper.searchBooks((query != null ? query.toString() : "@@@@"));
if (cursor != null) {
String[] from = new String[] {
BooksDBAdapter.KEY_AUTHOR,
BooksDBAdapter.KEY_TITLE,
BooksDBAdapter.KEY_GENRE,
BooksDBAdapter.KEY_PRICE,
BooksDBAdapter.KEY_PUBLISH_DATE,
BooksDBAdapter.KEY_DESCRIPTION,
//view we want to set results
int[] to = new int[] {R.id.author, R.id.title, R.id.genre, R.id.price, R.id.publish_date, R.id.description};
//create cursor adapter. which exposes data from a Cursor to a ListView
SimpleCursorAdapter cursorAdapter = new SimpleCursorAdapter(this, R.layout.search_results, cursor, from, to, 0);
myList.setAdapter(cursorAdapter);
//listview Click listener for selected results
//WAS PREVIOUSLY - myList.setOnItemClickListener(new AdapterView.OnItemClickListener()
myList.setOnItemClickListener(new OnItemClickListener() {
public void onItemClick(AdapterView<?> parent, View view, int position, long id) {
// Get the cursor, positioned to the corresponding row in the result set
Cursor cursor = (Cursor) myList.getItemAtPosition(position);
//fix this line. modify string value
// String searchValue = cursor.getString(cursor.getColumnIndexOrThrow("searchValue"));
String author = cursor.getString(cursor.getColumnIndexOrThrow("author"));
String title = cursor.getString(cursor.getColumnIndexOrThrow("title"));
String genre = cursor.getString(cursor.getColumnIndexOrThrow("genre"));
String price = cursor.getString(cursor.getColumnIndexOrThrow("price"));
String publish_date = cursor.getString(cursor.getColumnIndexOrThrow("publish_date"));
String description = cursor.getString(cursor.getColumnIndexOrThrow("description"));
// Set the default adapter
// Find the position for the original list by the selected name from search
for (int pos = 0; pos < nameList.size(); pos++) {
if (nameList.get(pos).equals(selectedName)){
position = pos;
break;
// Create a handler. This is necessary because the adapter has just been set on the list again and
// the list might not be finished setting the adapter by the time we perform setSelection.
Handler handler = new Handler();
final int finalPosition = position;
handler.post(new Runnable() {
@override
public void run() {
myList.setSelection(finalPosition);
searchView.setQuery("",true);
@override
//show list
//set searchview
mDbHelper.open();
//Clear all names
// what
try {
mDbHelper.open();
continue;
continue;
switch (name) {
case "author":
break;
case "title":
break;
case "genre":
break;
case "price":
break;
break;
case "description":
break;
}finally{
String result = "";
parser.nextTag();
return result;
@override
super.onDestroy();
mDbHelper.close();
@override
displayResults("");
return false;
@override
// } else {
return false;
@override
return false;
position = pos;
break;
@override
public void run() {
