First off, I'm glad that this is a place I'm less likely to get the smug cultists respond with "get a Mac".
I recently bought a 30" monitor that is capable of 2560X1600, and I'm pretty sure I'm not going to be able to get this out of this monitor. Things look pretty bad on it right now, very pixelated, poor definition. I'm running Win7, 64bit (home edition). I cannot get the screen resolution any higher than 1280X800.
I cannot even get 1080p out of this thing. It goes haywire (monitor gibberish). If I set the resolution to even 1920X1080, the monitor turns black and shows only colorful bar-code shapes (similar to the old 1990's screen savers).
My graphics card is shown on the computer as a GeForce 9200, but I think this was originally an 8200 that was "updated" with a new driver to "9200", according to some info I've read on some forums.
The computer (mini-tower) only has an HDMI output, and the monitor only has a DVI port. I'm using an HDMI-to-DVI cable (dual-link), although I'm being told that the HDMI output of my card is only capable of single-link.
I have used a single-link cord as well, no change.
This is the computer:
Acer Aspire AX1200-B1792A Desktop PC Athlon X2 4850e (2.5GHz) 4GB DDR2 320GB HDD Capacity 22" Windows Vista Home Premium 64-bit - Newegg.com
Can anyone help me get at least a little better resolution out of this?
Thanks!
Thanks!
