help with psx
J33P
hi im trying to get psx4droid to work on my evo, i downloaded a .rar game file, and then moved it onto the sd card, then went through psx and couldnt find it on the sd card.... am i doing something wrong
Emulator files are normally .rom files, not .rar files.
.rars are compressed files, like .zips, so you probably need to extract the .rom from there before psx will find it :)
ok so i downloaded the .rar files, like 20 diff ones, and none of them have a .rom file, most have a .sub file which appears to be the game, but wont play on here....
Do any contain a .ecm file? .ecm is another way to compress a ROM so you can download things even faster. Search for unecm tools on Google.
