Help With Rom Manager - Captivate - Backup
snadler
I am another New to Android Beginner. Samsung Captivate 2.2 Froyo Trying to Backup with Rom Manager before playing with roms. I am rooted and have titanium backup running fine but when i try to use Rom Manager, fix permissions i get the message: An errir occurred while attempting to run privileged commands. I checked in Super User and I see that Rom Manager is in there? Also when I do try to do a backup of the existing rom it brings up the blue option screen with the usual options to reinstall packages etc. reboot is highlighted so that is what i do. I have not reinstalled packages at all as i am not sure if i should or not. There is a yellow text section underneath that reads
Update media please wait
update media finished
"manual mode"
appling multi-csc
installing multi-csc
install default apk-files, please wait
install default apk-files, finished
I do not see a backup anywhere by the name it says it will create?
Any help would be appreciated......... :confused:
I'm having the same problems...stuck at the "installing Multi-CSC" step... not wanting to flash a new ROM as I'm not able to backup my current one.
