Help Help with Rooting ZTE GRAND X MAX
Kammo
Ok so I did a factory reset on my phone.
I got King Root & ZTE ZMAX TWRP.
Installed both, ran King Root.. Got message that says Root Successfully.
Started TWRP, clicked Install Recovery.. got message SUCCESS!
click on Reboot Recovery and the button lights up but does nothing...
Stuck at this point.
I want to move files, games and apps to SD card and make it the default as well
as get rid of the junk they installed on the phone that I will NEVER use.
Using a ZTE X MAX phone, Android Version 4.4.2, Build Number Z787V1.4.16
Any help to what I need to do to get this to work would be awesome!!
Kammo
