Help with several Marshmallow update issues??? Anyone?
doverbey
Like others, I have had several issues on my S6 since the update. ANY help would be appreciated
1) TOP Priority - phone calendar and Google calendar on my computer will NOT sync! HELP (I use both the native calendar and Touch Calendar on my phone both of which have worked well until update).
2) Really annoying:
Stitcher app doesn't buffer. It just stops playing about every 90 seconds and I have to hit PLAY again to get the next 90 seconds of a podcast.
3) Annoying but I can live with them :
I have several different weather apps and have tried the widget for each one but the widgets will not update and mostly "fail to load." The apps themselves are working fine.
No spaces automatically inserted in Chrome when searching
4) Solved but it totally freaked me out as I was on my way somewhere new -
Navigation in Google Maps wouldn't work. That took several hours to troubleshoot and I did piece together a fix (if anyone else needs help, shout out) that did not require the FACTORY RESET that was suggested by an "expert" in the Google Support Forums.
