help with transferring video from phone
Grldisney
I have an hour video I need to transfer to youtube or my email. Can you help a newbie to do this...please help with step by step directions. Thanks
Just connect your phone to your PC using the included cable. Answer the question on your phone so that it allows mass storage access. Open the drive that appears on your PC... there's a folder called DCIM somewhere. Open that. There should be another folder inside: Open that too.
Inside you'll find all your photos and videos, ready for copying or uploading.
Or go to the Gallery and select the video and then the Share icon (circle with 2 arrows) and that'll give you the option of YouTube, Mail etc.
If it's an hour long video, you won't be able to upload it directly from the phone. He will have to transfer it to a computer first.
