Help Help with using my new phone
Can anyone tell me:
1: The phone only makes a noise once when i get a text message through. How can i change it so I get notified every 2 mins or so for that text message until I read it.
2: How do i turn applications off so they are not running in the back ground? or do I have to just press the home button in the middle?
Ta x
1. Not sure you can with the stock app unfrotunately, you might want to try SMS Popup, which just handles the notifications, or an alternative SMS app, like GoSMS/Handcent.
2. You don't :p Just let Android handle task management, if you start killing stuff yourself, it can actually have a negative impact on battery life. There's some info and another thread here: http://androidforums.com/htc-one-x/532012-taskmanager.html
Hope that helps! :)
