Biggest Fro
I know it doesn't work with sense ROMs, I'm using CM6.
I have the Wiimote connected to the phone, it shows each key press etc.
But when I go to PSX4Droid or Gameboid and select "Use Input Method" it doesn't do anything. The Wiimote wont work as a controller. If I try to map the keys, it wont map them using the Wiimote.
Any Ideas?
Any Ideas?
