Help!!
Exactly how did you uninstall it? If you remove it, it should ask for a different launcher at startup.
Try going to settings>apps>more>configure apps and set the default launcher to something else. then uninstall Nova and reboot.
And this is an unrooted device (so it's not been changed into a system app for example)? You've not set it as a device administrator (which would prevent uninstalling until unset)?
